Still having problems with HTML Planes
Home › Forums › General Questions › Still having problems with HTML Planes
Viewing 6 posts - 16 through 21 (of 21 total)
  • #87029
    Indeed, Firefox works way better with this feature. You might reduce the pixel size of the iframe when using the “create page with html”. In some cases this fixes inconsistencies introduced by the Chrome/Edge browser.
    #87031
    gf3d
    Which size do you mean with the pixel size?……
    it now has a width of 4…..a height of 2.25 and a res of 1920…
    when i change any of these numbers it doesn´t fit anymore to the 3D palne which is used for the fade in
    Greets
    Ger
    #87034
    I was referring to the 1920 resolution. We have some Safari issues with “Webpage Inside 3D” demo and managed to fix it by reducing the resolution specifically for that browser.
    In general I’d suggest reproducing this bug using a minimal scene with basic planes and sending this example to us. This would help a lot with debugging.
    #87035
    gf3d
    Hi Alexander,
    reducing this 1920 value is not the solution….in that case not all of the Webpage is shown on the plane….it needs scrolling then…which is not what i need…
    I will setup a basic scene as it is right now in Max 2025 and i will supply you with it as well #as with the verge data…
    Greets
    Ger
    #87036
    gf3d
    Hi Alexander,
    i just send a mail to your Mail account ( info@ )
    just start the link for the data needed
    Greets
    Ger
    #87052
    I think I know where the root of the problem lies. There is a gotcha in web browsers when iframes are stealing the focus from the main page. To make the keyboard keys work again you need to force the focus back to the main page with the call method puzzle. I’ve added it right after you switch your camera back and everything works just fine!
