PathTracer first test
Home › Forums › Projects › PathTracer first test
  • #88586
    NaxosCG
    Hello there.
    I’ve kinda made it ! An On-demand Path-tracer within Verge3D app !
    Still a lot to make, but first test is very promising…
    #88588
    Wow, looks cool! How did you achieve that?
    #88589
    NaxosCG
    Implemented an open source pathtracer as a verge3D plugin, of course with some help.
    The “move-stop-render” is only ok because of my GPU (rtx 5070) and the simplicity of the scene : don’t espact this on lower machines or with large scenes.
    Instead, you could just have the render, then stop, then move, then render again.
    It is not as good as the one pathtracer i’ve mentionned once in the forum (https://threejsresources.com/tool/lgltracer), but it works.
    No need to convert shaders as soon as i use “classical” verge3D ones (USD or physical under 3dsmax : USD works better).
    #88614
    Great work! Keep us posted! :good: :good: :good:
    #88624
    NaxosCG
    Here is a new one, no pathTracer, but RT Raytracer now…
    #88628
    Cool :good:
