Home › Forums › General Questions › Still having problems with HTML Planes
- This topic has 20 replies, 4 voices, and was last updated 6 months, 1 week ago by
Alexander Kovelenov.
2026-04-15 at 9:04 am #86957
gf3d
CustomerHi Guys,
i´m working again on this HTML Plane project we´ve been discussing about before…
Its created with Max 2025 and the latest version of Verge……
At the starting point its a first person camera……..which runs fine at the beginning
In the scene you can see several trussing constructions….showing the image of an Internett
Site…..when clicked on the small button on the right down corners ( with the finger shown)
a 3D object shows up showing the same image as on the trussing….
the camera is swapped to a different one….which is fixed ……sofar so good…as soon as this image is shown its beamed to a different position …… sofar so good…..
at the same time a HTML Plane is beamed to that position…showing the actual Homepage….
again so far so good…..now things happen which are strange……
As long as i have not moved the first person camera everything is fine……the HTML Plane
is interactive like it should……after going back….using the return button…which shows up
1…the first peson camera doesnot react to the keyboard input ( WSAD )
2… after having moved and rotated the camera ….I can still call up the HTML Plane as before
….but its not interactive anymore….it doesnot react to any Mouse action…..I had this problem a couple of month ago……we discussed about it….
I thought it would have been solved in the meantime…..https://www.gf3d.de/Roadtest_Walk/Roadtest_Walk.html
Greets and thanks for any help
Ger
2026-04-15 at 9:10 am #86959gf3d
CustomerBy the Way
I´ve noticed that this problem with the HTML Planes doesn´t show up in Firefox
Greets again
Ger
2026-04-15 at 4:09 pm #86973
xeonCustomerFrom the what it seems like…I dont think the first person camera is working properly.
It only seems to zoom but never change its position. Which is not what an first person camera should be doing. If you scroll your mouse wheel to zoom back out…after you have walked down the path..you will realize..the camera never moved.W = zoom not move…something odd about that.
Tutorials - https://www.xeons3dlab.com2026-04-16 at 7:53 am #86983
Alexander KovelenovStaff2026-04-16 at 9:56 am #86991gf3d
CustomerHi Alexander……the only icons that are active are the once on the trussing with my Homepage……..so the first at the left side…..
It should work….
Greets
Ger
2026-04-16 at 1:51 pm #87000
Alexander KovelenovStaffStrange thing, not all icons operate correctly… Anyway, it appears you have an HTML element that powers the “plane with html” puzzle is still covering the screen preventing keys to function properly. Just remove the corresponding object after you done with closing the website and see if it works.
2026-04-17 at 5:55 am #87002gf3d
CustomerHi Alexander,
i was thinking the same thing that some objects were still covering the HTML Plane……
But its not….the 3D Object which fades in with the effects is moved out of the way as soon as
the HTML plane appears……the dummy which defines the position of the HTML Plane is even hidden….it is linked to the first person camera…..Using firfox all works well….any other browser doesn´t work…
really strange thing…
Greets
Ger
2026-04-17 at 7:03 am #87004
Alexander KovelenovStaff2026-04-17 at 8:46 am #87005gf3d
Customerwhich plain do you mean?…the HTML Plain or the 3D object?
2026-04-17 at 12:15 pm #87010
Alexander KovelenovStaff2026-04-18 at 7:01 am #87020gf3d
i will check that….but this means that the HTML Plane need to be recreated everytime its needed…..and its questionable whether it work well then…we will see……
Greets and a nice weekend for you
Greets
Ger2026-04-18 at 5:14 pm #87022
visualizerParticipantI checked the link in edge. I think everything worked well.
after clicking the anti clockwise button ( return button ) WASD was working fibe.
did you fix it already?-
This reply was modified 6 months, 2 weeks ago by
visualizer.
2026-04-20 at 6:11 am #87024gf3d
CustomerHio Visualiser,
no i did not change anything so far…….
As i Stated before …in all browsers i checked so far …only in firefor all did work as it should…
In Edge the camera works as it should but not the HTML Plane…after i moved the camera..
In Chrome nothing works as it should….so i think its not a problem with Verge but merely
with the browsers….which is realy strange because this is the first time i have problems with Chrome….so far this browser worked well…even with my bigger projects……Greets
Ger
2026-04-20 at 6:49 am #87025
visualizerParticipantYes!
I checked in Opera, Chrome & edge …
looks like its not consistent as expected.2026-04-20 at 7:00 am #87026gf3d
Customermaybe this is something the verge guys might check…….Pls. check firefox as well…
@ Alexander…..maybe this is something you guys might check as well
Greets
Ger
