can you help me fix this flickering ?
Home Forums Graphics / 3ds Max can you help me fix this flickering ?
  • #86226
    NaxosCG
    Hello there !
    I don’t really know why, but i get some random flickers in my new project (see video)…
    i have a wide spotlight in front of the letter to get the light effect on the floor, but not sure it is related.
    #86228
    NaxosCG
    strange also is that it seams to mimmic the iOS bad rendering i told you about in this post.
    Not sure, but the shape of flicker seams similar to the black strange render on iOS…
    ORM maps auto creation
    #86231
    No, I don’t think these both issues are related. Here we see some shadow bug, but AR iOS renderer (made by Apple) does not inherit Verge3D shadows at all.
    Unfortunately, I can’t reproduce this issue on my devices. Could you please do some tweaks and see if the issue still persists:
    1) slightly reduce angle of your Spot light (making it less than 90/180 degrees).
    2) change the type of the shadows
    3) disable cast / receive setting on any objects you don’t need to cast / receive shadows
    #86238
    NaxosCG
    Thing is it used to work with my first test, using USD shaders, same spot, same params…
    I may have changed shadows param in export settings…
    #86240
    NaxosCG
    changed back shadows to ESM, lowered spot from 164 to 140 wide, now it is ok.
    Many thanks !
