Problem with showing image sequence in Verge 3D
Home Forums General Questions Problem with showing image sequence in Verge 3D
  • #86682
    gee_lau2000
    Hi guys,
    I’d like to ask if it’s impossible to display an image sequence in Verge 3D?
    #86684
    A sprite sheet or as a video will work the best.
    If you are thinking of having a folder filled with sequenced images and running through them…you can but play back will be affected by load times causing the sequence to play back at an uneven pace…..unless you preload all the images and in that case….you are better off with a sprite sheet or a video.
    #86697
    gee_lau2000
    xeon, Thank you so much!!
    I’ve found that video tutorials are much more efficient for me. However, it’s quite hard to find good resources other than yours! I do find some of your videos a bit challenging, though, as I’m still building up the foundational knowledge to fully follow them.
    #86699
    No problem….we all started from where you are now. It wont be long before you have your footing and helping solve problems for others too.
    So the first question I have for you is what resolution are the images?
    Second question is how many images are there?
    Thirdly…what devices do you want these images to play back on (mobile phones, tablets, desktops, just one of these, or maybe all of these?)
    Lastly, what is the purpose and function of these images in your project.
