Error Loading ParamBlock2 / Invalid file – only partially loaded. ILoadImp::LoadEntity failed
Home › Forums › Graphics / 3ds Max › Error Loading ParamBlock2 / Invalid file – only partially loaded. ILoadImp::LoadEntity failed
  • #87743
    Moin Rahman
    Error loading files which seem to be an issue with Verge3D plugin on 3DS Max : Error Loading ParamBlock2 / Invalid file – only partially loaded. ILoadImp::LoadEntity failed
    Is there a solution to this aside from Merge files into new projects? This is an non-ideal fix as some things are lost through merging…
    #87744
    Could you please provide more info on this. What version of Verge3D and 3ds Max are you using? Is Verge3D installed and working properly?
    #87748
    Moin Rahman
    Hi Alexander,
    I’m using 3DS Max 2025 and 2026 with the latest version of Verge3D – I downloaded it and updated a few weeks ago. However this has been an on going problem for over 2 years now – I get the same error regardless of version – since updating from the versions of Verge/Max that I originally made the scenes with, I just didn’t realise until now it was a Verge3D plugin issue…
    #87749
    Moin Rahman
    Happy to send you a scene file that produces this error – let me know where to send to…
    #87750
    I see,
    It appears the scene was corrupted at some point. If you just create a new basic scene and open it in 3ds Max, does the issue persist? Another test case would be trying to open the scene when the Verge3D plugin is disabled (uninstalled).
    If nothing helps, feel free to upload your max file to some cloud storage and attach the link here.
    #87751
    Moin Rahman
    It’s happened to a lot of files, though not all, so many have been corrupted if this is the case. It doesnt happen with newer files and it still occurs when I have verge3D uninstalled…
    As an example:
    https://www.dropbox.com/scl/fi/d7csj1lqfy8fdmvdnhsb5/Visor-Animation-R00.max?rlkey=2fv2yeohdw07czss5ar00savt&dl=0
    #87753
    The issue appears to be not connected with Verge3D. Here is the info from the 3ds Max debug log:
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormBitmap
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormNoise
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormDistance
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormColorCorrection
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormFalloff
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormMix
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormDirt
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormMixMat
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormCamera
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: tyflow_2023.dlo - tySmooth
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormSunLight
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormDisplacement
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormLight
    2026/07/11 19:10:27 WRN: [07692] [11012] Missing dll: fstorm.dlr - FStormRender v1.5.3n
    2026/07/11 19:10:30 ERR: [07692] [11012] Error Loading ParamBlock2
    2026/07/11 19:10:30 ERR: [07692] [11012] Invalid file - only partially loaded. ILoadImp::LoadEntity failed
    2026/07/11 19:10:32 ERR: [07692] [11012] File Open Failed:
    Possible reasons for that issue – missing FStorm or tyFlow plugins (or some version mismatch).
