Annotations Stay open when clicked through too quickly
Home › Forums › Puzzles › Annotations Stay open when clicked through too quickly
  • #88405
    emadamsinc1
    I am resubmitting this here because I did not find an answer in the general chat. I have a scene where I move through annotations using arrows and a list. When you click the arrows too quickly the annotations that are set to open and close as your proceed do not close and then I wind up with open annotations just sitting and blocking the scene. I tried to fix this by setting a variable to true and then adding a timer screenshot below but I don’t think I am doing it right. Has anyone else experienced this and have a workaround?
    Thank you,
    Emily
    #88407
    Can you share the project or simplified example.
    #88408
    emadamsinc1
    Yes, please find the file attached with the attempted solve from the earlier screenshot. The attempted solve when double clicking the right button just results in 2 getting skipped and one and 3 being open together because step 2 is where annotation 1 was supposed to close but because double clicking skips that step other actions do not trigger. https://www.dropbox.com/scl/fi/dnxg3p38q46hfvwlkuuxm/0916-test.zip?rlkey=zxig166wabc3p343envsot04y&st=6c60nawx&dl=0
    It happens because no matter camera already moves or not the new session of moving starts when you click next or back buttons, so you need to add some checks for camera: moves it or not.
    #88422
    emadamsinc1
    Thank you for taking the time to look at this. I will work on adding in.
