Clipping Planes
Home Forums Graphics / 3ds Max Clipping Planes
  • #63525
    anghel2001
    I’m trying to use the clipping plane helper in 3Ds Max, but I can’t select the object on which it is applied.
    The dropdown where I should select it is empty.
    I can’t find any documentation, either.
    Does anyone know how to use them?
    Thanks!
    #63530
    Maybe it should be a group of objects? For example, in Blender the influence can be applied only to groups aka collections.
    Solving any problems with Puzzles or JS code. Fast and expensive.
    #66246
    digi
    You need to create a selection set (select your objects and then edit–>manage selection set–>create new set).
