Set color in material using hex code
Home Forums Puzzles Set color in material using hex code
  • #32605
    Daniel Garcia
    Hi!
    In the applications I’m developing I use the puzzle “set color in material to R G B”. I think it would be a good adittion to give the posibility to change the color not only using RGB but also with the hexadecimal code.
    I use in blender and in wordpress hex color code and it is pretty annoying to convert hex to RGB for every color I use.
    I don’t think is a hard upgrade to make. It could be done by using the same puzzle but detecting if the input is a vector 3 or a string, or simply add a new puzzle that makes the job.
    Thanks for the great software!
    #32611
    there IS such the option!
    #32618
    Daniel Garcia
    Great! I didn’t know. Thanks :good:
    #32622
    Sure! :good:
