How to pick cloned objects?
Home › Forums › Puzzles › How to pick cloned objects?
  • #19228
    woori9000
    Hi, guys~
    Is there any way to pick the cloned object?
    I know how to clone some object already placed in the scene using mouse click.
    When I click the cloned object in the above method, I want to clone the picked object again.
    I tried this several times, but the cloned object was not picked again.
    Here’s an image of the puzzles used:
    #19234
    You are on the right track. I tried your setup: the clones are actually created and added to that list. The when clicked puzzle, however, registers click only at the moment when it is interpreted (upon app startup). The newly created clones therefore are not clickable.
    A possible solution to this would be to use the when clicked puzzle again for the cloned object. You might use a procedure to avoid copying puzzles.
    #19464
    woori9000
    Thank you very much for your advice.
    I have thought and tried a lot of time to apply your advice to my puzzle.
    I got some results, which was close but not what I wanted.
    Attachments are images of the puzzle I tried.
    The mistake I made in my puzzle is probably due to recursion.
    Unfortunately, I don’t seem to have the ability to solve this.
    I need a hint.
    Please, can you tell me what I did wrong?
    #19577
    Can you also attach a sample project please? We’d take a look.
