change several materials params in once
Home › Forums › Puzzles › change several materials params in once
  • #29415
    NaxosCG
    Hello there,
    I would like to be able to change the base color of several materials in once.
    I thought to create a list with the materials, but there is no “base color” param available for the list variable, any idea ?
    #29421
    Try to use Text Inputs in the Puzzle settings to change inputs in multiple material.
    #29445
    NaxosCG
    Sounds good, but what exactly should i put as text ?
    “Base Color” ?
    #29447
    The name if the inut you want to chage if it’s different in each material then create a loop with list if all nodes and put material change puzzle into it with variable in text input if the node.
    #29448
    NaxosCG
    Ok, i see, a bit too far for me… i’ll do it manually…
