Assign texture to object
Home › Forums › Puzzles › Assign texture to object
  • #55658
    junglist
    Hello everyone,
    I was wondering is it possible to assign some texture to object. Without using replace texture.
    The issue I’m facing is that after creating copy of object I can only replace texture to all the copies and not an each individual copy.
    I know I could create more materials inside model and hide them to achieve desired result. But I wonder is there a way, to create a material or material copy that could later be customized.
    #55659
    That’s because clones have the same material. You can’t do what you want via puzzles. You need to clone the object’s material and change its name.
    #55663
    junglist
    Thank you :good:
