walkthrough navigation
Home Forums Puzzles walkthrough navigation
  • #52239
    okfir
    Hi all,
    I am new to verge3d and puzzles and I was asked to make a virtual walkthrough in an exhibition area with keyboard navigation, I tried to start with the Snowballs Vr project but it is too complicated for my level, is there any tutorial or simple project to learn?
    Thanks in advance
    #52260
    You may want to start with a simple scene you create…
    place some simple geometry in the scene.
    Create your floor object.
    Then create a Collision Material Object that sits on top of the floor that is like a second floor using a different material. This will be the boundary for the camera.
    Select your camera and go to the Verge3D settings and select Controls and then choose First Person. Assign your Constraint Material here.
    Then give your scene a test.
    Good luck.
    #52269
    okfir
    Good luck.
    Thanks, I will give that a try
