Making two animations run with one click
Home Forums Puzzles Making two animations run with one click
  • #2959
    kimholder
    I have set up two animations to run with one click, and it almost works, but while one animation runs once and then runs backwards once, like it should, the other only runs once forwards and doesn’t then run backwards. Clicking either of the large objects on the left should make that happen.
    From the list of puzzle pieces it really looks like there are other ways to set this up, but i really don’t know Javascript and can’t figure it out.
    verge3d puzzle piece setup
    version on the network
    (There was a separate animation i just deleted because it was redundant, that won’t show up on the linked version for a bit, but the problem is the same.)
    #2964
    kimholder
    I think i’m starting to understand how i can do this by adapting the E-learning example. I’ll keep working on it.
    Or, i could redo the animations so there is no need to have them reverse, and then the problem should go away.
    #2980
    Yes, it’s known problem with reverse aniamtion it’s doesn work in some setups, we’ll fix it in one of the next releases.
