- This topic has 15 replies, 2 voices, and was last updated 1 month, 1 week ago by
xeon.
2026-01-15 at 2:55 pm #85980
c4ccCustomer2026-01-15 at 11:04 pm #85983
xeonCustomereasiest way seems through JS does it need to be puzzle based?
Tutorials - https://www.xeons3dlab.com2026-01-15 at 11:41 pm #85984
xeonCustomerhere is a puzzle based solution…for a specific key:
https://v3d.net/1eh2Xeon
Tutorials - https://www.xeons3dlab.com2026-01-16 at 8:13 am #85985
c4ccCustomerTried it for animations, unfortunately it didn’t work, help? Need animation played once when key is pressed and released, and looping animation played when key is pressed/held down after certain time
This reply was modified 1 month, 2 weeks ago by
c4cc.
2026-01-16 at 4:46 pm #85990
xeonCustomerThe initial question was a key down timer….the solution provided does that…but what you are asking now is a different question that has many different solutions
Here are two examples:
Press the 7 key and it will jump
Hold the 7 key and it will rotate…. no time gap between the two eventsPress 8 and it will jump
Press 8 and hold the 8 key for 3 seconds and it will jump then rotate indefinitely until the 8 key is released.project file located here: https://v3d.net/1eh2
demo here: https://v3d.net/1ehgHope this helps.
xeon.
Tutorials - https://www.xeons3dlab.com2026-01-16 at 7:41 pm #85999
c4ccCustomerSo far this seems to work, thanks
2026-01-20 at 5:37 pm #86014
c4ccCustomerI’m trying to recreate above javascript into puzzles to detect time when a key is held down, compared to time a key is released, so I can play different animations, depending on a key being instantly pressed, vs a key being held down for some time.
While I can cancel the immediate key press animation, to play a key held down animation, the key held down animation when key is released STILL plays the immediate key press ending animation. I don’t want the key held down animation to play the immediate key
press ending animation.How do I get the key held down animation to play its own ending animation when the key held down is released? Where did I go wrong with these puzzles
This reply was modified 1 month, 1 week ago by
c4cc.
2026-01-20 at 11:31 pm #86016
xeonCustomerJavascript would make this so much cleaner I think but here is a puzzle solution:
Hold the 8 key down briefly. ( less than .5 seconds ) it just plays animation one. Hold the 8 key down for more than .5 seconds it will play animation one…then loop animation 2…then when you let go of the 8 key…it will play animation 3. Animation three only plays after the 8 key is held down.
Project file here: http://localhost:8668/manage/?app=X3L_key_down_timer#:~:text=X3L_key_down_timer.zip
Tutorials - https://www.xeons3dlab.com2026-01-21 at 2:18 am #86017
c4ccCustomerSorry, I can’t download the file, could you reupload it please? Thanks-
c4cc.
2026-01-22 at 5:58 pm #86025
c4ccCustomer2026-01-22 at 6:39 pm #86026
xeonCustomerGlad you were able to make it work.
You may want to consider minimizing the amount of stuff that is run through the “Everyframe” puzzles. You could consolidate and have only one “Everyframe” puzzle and pull the onkeydown event listeners out of the “Everyframe” puzzle since they are event based and don’t need to be triggered or retriggered every frame. You may find some performance gains.Xeon
Tutorials - https://www.xeons3dlab.com2026-01-23 at 3:18 am #86027
c4ccCustomerThanks for your suggestions, I’ll look into it
Just wondering, weren’t your original onkeydown event listener puzzless inside the everyframe puzzles?
c4cc.
2026-01-23 at 6:30 am #86029
c4ccCustomer2026-01-23 at 4:22 pm #86033
xeonCustomerThe first image is probably your most efficient means.
You only want one key down event listener…within it you can put the If statements that control the various key conditions. Splitting them up may seem organizationally efficient but from a program perspective can lead to problems.All of the example puzzles I provided are in the current project. In the main tab is the first iteration, the last tab is the second itteration and the middle tab is the most recent.
Tutorials - https://www.xeons3dlab.com2026-01-23 at 5:04 pm #86034
c4ccCustomerThe first image is probably your most efficient means.
You only want one key down event listener…within it you can put the If statements that control the various key conditions. Splitting them up may seem organizationally efficient but from a program perspective can lead to problems.Agreed, I only split those puzzles up as reference for future programming, I won’t use both sets together
Also, any way for me to further simplify/optimize these puzzles?
c4cc.
