How to trigger Event listener for HTML element anytime?
Home Forums Puzzles How to trigger Event listener for HTML element anytime?
  • #84576
    c4cc
    As yuri says here
    hi,
    yes, you can enable the event puzzle at any particular moment not just when the Verge3D scene is loaded. To do this, you can put this event puzzle inside a procedure puzzle, and then trigger it from your page via JavaScript
    https://www.soft8soft.com/docs/manual/en/puzzles/Procedures.html#calling_procedures_javascript
    I tried, but it doesn’t work when html document’s element is clicked on while verge3d is initialising. Only after does it work. Any way to get Verge3d puzzles, like HTML events to run before app is initialized?
    #84599
    c4cc
    Tried in both html document and application.js, still doesn’t work
    Edit: fullscreen error is solved in this post and the last. Fullscreen puzzle variables values’ now can be updated when fullscreen and reset to default values when smallscreen
    :good:
    • This reply was modified 6 months, 2 weeks ago by c4cc.
    #84606
    I believe the issue is that your params in the init tab are not applicable in the main tabs (once your app is fully loaded). Please check out this post for a solution.
