Highlight object behind other object.
Home › Forums › General Questions › Highlight object behind other object.
  • #21441
    zeitgeist
    Hey,
    I´m looking for a way to highlight an object behind an another object when hovering over it.
    I´ve attacked a picture to show the effect I´m after.
    I want to highlight different flats inside a building on hover.
    The only way I´ve found so far is the outline feature, but would prefer to have an full overlay.
    Any help is much appreciated.
    Thanks and br
    #21450
    hello!
    at the moment this is can be done only with coding, by disabling depth test:
    v3d.SceneUtils.getMaterialByName(v3d.apps[0], 'myMaterial').depthTest = false;
    we’ll make it possible with blender or max UI
    #21467
    zeitgeist
    Thanks for the reply! I´m glad it is possible with coding.
    Still not sure where I have to run this code :/
    Could you please point me in the right direction.
    Thanks and br
    #21469
    you can use either of methods described here
    https://www.soft8soft.com/docs/manual/en/introduction/Using-JavaScript.html
    #21483
    zeitgeist
    thanks, so far so good.
    Unfortunately this doesn´t work if the sphere is inside the box, because the hover will not be recognized.
    Is there a way to trigger the hover effect even if it is inside?
    #21487
    you can try to make an invisible mesh above your objects to make it responsible for hovering (if I understood correctly)
