enable /disable rendering when I go in and out the full screen
Home › Forums › Puzzles › enable /disable rendering when I go in and out the full screen
  • #28319
    lopatam
    Ciao,
    I’ve done the swiss army tutorial for the antialiasing, great by the way.
    When I go fullscreen my rendering is disable until I move the camera and I see the last frame rendered with a lower resolution and distorted because the fullscreen adapt the image to the new resolution. After I moved the camera the render is enabled again and the image changes with a annoying visual “click”.
    I have to put a puzzle like “when fullscreen is clicked enable render”
    Is it possible?
    Thanks in advance
    Gianmarco
    #28320
    This was solved in last version of the engine in 3.2.0-pre2.
    #28322
    lopatam
    I’m still using 3.1. Thanks!
    #28357
    GLiFTeK
    i’m having an issue with this.
    i have this setup…
    after i fullscreen the viewport window, it ceases rendering.
    USING Version: 3.2.0pre2
    #28366
    We can’t reproduce the issue. Can you create a simple project with this behavior and attach it here?
