Wireframe visible depending on viewing angle
Home Forums Graphics / 3ds Max Wireframe visible depending on viewing angle
  • #32717
    jamjam
    Hey,
    We are using 3ds max and PhysicalMaterial for our model.
    Depending on the viewing angle the wireframe starts to get visible.
    I´ve attached the reduced max file with texture.
    Gif showing the issue: https://ibb.co/yRLGc7Q
    The materials are PhysicalMaterial with a single base color map.
    Any idea what causes this issue?
    Slightly Off-topic: Is it possible to add the verge3D Parameters to a existing material?
    Thanks
    #32724
    jamjam
    Seems the problem is cause by the UV edge.
    The texture has a 2px padding.
    #32730
    Yes, because of that and the solution is to bake with bigger padding.
