Variables and procedures
Home › Forums › General Questions › Variables and procedures
  • #46548
    georgeslambert
    I’m in a trouble with alot of duplicated puzzles in an indexed chain of actions that could be solved by linking a procedure launch to a variable state : let’s say :
    If var state = x
    do procedure x+1
    Is there any way to handle this with puzzles?
    Thanks a lot!
    #46557
    georgeslambert
    The procedure is named by number or contains number to be compared to variable value (don’t know if this is more understandable)
    #46576
    you can trigger a procedure by its name using the exec script puzzle:
    https://www.soft8soft.com/docs/manual/en/puzzles/Advanced.html#exec_script
    (see the usage example for the PROC variable)
    #46589
    georgeslambert
    Thanks Yuri,
    But honestly this is chinese to me. Explanation in the wiki is quiet abstruse for somebody limited in coding science.
    I took a snapshot of one my logic block.
    I have (9) evolutive steps to be performed from (7) different actions menu. A button allows me to go to next or to previous step before launching action.
    In this case, the “positive” button triggers state 6 when step variable is at 5.
    The “negative” button triggers state 4 when step variable is at 5.
    My life should be changed if i had a mean to say
    “trigers (x-1) state when variable is at x” (backward) or
    “triggers (X+1) state when variable is at x” (forward)
    and create a procedure with it for my buttons back and forward.
    Any idea how that could be done? So far,my puzzle board looks like having no ends.
