Uncaught ReferenceError: appInstance is not defined
Home Forums Programming Uncaught ReferenceError: appInstance is not defined
  • #49776
    tgleason
    I’m trying to write JS code to change my material color. I know that I need to use the function setMaterialColor().
    I added the function to my app.js file. I thought it should already be included by the puzzles, but I manually added it. This function then depends on a var called appInstance.
    How do I make this available to my app.js file?
    thank you,
    Tom
    #49777
    tgleason
    Similarly, I’m trying to use this function and I don’t know why it’s not already available…
    Uncaught ReferenceError: Vector4 is not defined
    #49803
    tgleason
    Sorry to bother anyone, but it seems to help me break through a problem by posting on a forum even if I don’t get any answers. Maybe it’s easier to see that I’m looking at things wrong or asking a silly question that way.
    Well, I was thinking that I would HAVE to code because I couldn’t figure out how to do certain things in Puzzles. Then I went back and looked at the examples and realized there MUST be a way. Once I figured out how the Puzzles work, I’m impressed with how flexible they can be. Still moving forward nicely with my prototype, Thanks!
    #49813
    sorry for not replying earlier.
    yes you can do most things with the puzzles alone.
    for using JS with Verge3D, see this doc https://www.soft8soft.com/docs/manual/en/introduction/Using-JavaScript.html
