scatter objects on mesh surface
Home Forums Puzzles scatter objects on mesh surface
  • #82453
    ive tried to export empties on the mesh surface where i want to place objects, ive tried exporting the actual objects as instances, but the export becomes extremely time consuming, and the .gltf file heavy, when reaching for up to 100 000 empties.
    can i in puzzles, clone a object and repeat it on the surface of another mesh?
    I want to create a large forest, and have a system were the visibility of the trees is based on distance to the camera.
    #82454
    You can use the clone object puzzle to make instances and raycast to position them on your mesh (to calculate the require point of intersection between the ray and the geometry).
    #82567
    QiangGe
    MultiScatter demo
    Even without shadows enabled, it still easily crashes when the instance count exceeds 2500. Proceed with caution.
    • This reply was modified 9 months, 2 weeks ago by QiangGe.
