Puzzles in several scenes
Home › Forums › General Questions › Puzzles in several scenes
  • #41681
    troskhy
    Hi all… the project i’m testing to do in V3D consists in 4 diferent scenes. I have 3 scenes created at this time, with objects, material, etc properly renamed..
    My problem is that when i go to the puzzles, i only find the objects from the main scene in the dropdown selector…
    What do i have to do to see the elements from the other scenes so i can make the interactivity??
    Thanks!!!
    #41762
    Hola !
    En las aplicaciones de ejemplo hay una que utiliza varias escenas, jewelry_configurator, tal vez tengas aquí la respuesta.
    Saludos !!
    #41799
    You can load each scene at strartup in puzzles so you will se al object that loaded for this file, then create logic for this scene and unload it when you finished.
