problem with mobile safari on iOS
Home Forums Puzzles problem with mobile safari on iOS
  • #25247
    tintobrass
    i have a problem with mobile safari on iOS
    i use Verge3D woocommerce plugin
    i want to hide an object when value of select changes, but nothing happens
    Second problem is when i use div’s with color for changing color variations – same thing – when i click them on desktop – it works, when i click them on mobile – nothing happens
    on pc and macosx works like a charm
    here’s my puzzles screenshot – any ideas?
    #25272
    it looks like the ‘change’ event does not work properly on ios
    https://stackoverflow.com/questions/8004227/ios-select-onchange-not-firing
    #25273
    tintobrass
    ok – is there any other option i can use to make it work on ios?
    #25277
    try the workaround mentioned by the link above
    #25278
    tintobrass
    found another workaround
    used “WooCommerce Variation Swatches” plugin by RadiusTheme to set my variations as images, then i used other puzzles set – screen attached
    works like a charm on every platform including ios safari
    #25293
    excellent! thanks for sharing your solution! :good:
