Possible Error in removeEventListener (Verge3D 4.10)
Home Forums Bug Reports and Feature Requests Possible Error in removeEventListener (Verge3D 4.10)
Viewing 13 posts - 1 through 13 (of 13 total)
  • #85734
    Thomas Fabini
    Hi guys,
    since I upgraded to 4.10 (which I need for compatibility with Blender 3.6 and older Projects)
    it seems that i can’t remove event listeners which were added with the ‘add event listener with callback’ puzzle.
    ‘remove event listener with callback’ puzzle seems broken.
    In function ‘removeEventListener’ ‘_pGlob.customEvents._listeners’ seems to return always undefined.
    const customEL = _pGlob.customEvents._listeners;
            if (customEL && customEL[type]) { ...
    I’ve came to check this because after updating a project, event listeners kept firing multiple times which they hadn’t in 4.9.0 (as far as I recall).
    Thanks,
    Thomas
    #85742
    Hi Thomas,
    Indeed this is a bug due to internal “_listeners” array being wrongfully exposed to Puzzles. We’re going to fix this in the upcoming Verge3D update. Thanks for the report!
    #85745
    Thomas Fabini
    Hi Alexander,
    Thank you for confirming this.
    Since 4.10 is the last version of Verge3D which is compatible with Blender 3.x could you update this version, too, keeping compatibility with older projects as the last up-to-date version for 3.x projects?
    In 4.10 you added support for unique id’s, objects and animations both, which I’m missing in 4.9.2. (there are workarounds, but having the puzzles is certainly more elegant).
    Ah – and merry Christmas and happy holidays to you and the team!
    Thomas
    #85768
    Hi and Merry Christmas,
    Unfortunately, it’s against our company policy to issue fixes for outdated releases. The only workaround I can suggest (works for both 4.10 and 4.11) is to open visual_logic.js after saving it in the Puzzles editor and replace _pGlob.customEvents._listeners by _pGlob.customEvents.t just in one place.
    #85911
    Thomas Fabini
    Hi Alexander, a happy and successful New Year 2026 to you and the Verge3D Team!
    Thank you for you reply and the workaround you are proposing.
    The company policy and the reasons for not updating an outdated version, I understand. In this particular case I’m not really happy about the repercussions, but I respect it since it’s necessary from a developers point of view.
    Regarding the workaround you are proposing – that is too risky for production and working in a team. Each single export needs to be checked, each time when saving the error creeps back in.
    I’m considering working with a modified puzzles script (which at least is a one-time change per installation) until older projects are finished and we are able to move to a current version of Verge3D.
    Thank you,
    Thomas
    #86131
    This bug has been fixed in Verge3D 4.12 pre1. Feel free to check!
    #86144
    Thomas Fabini
    Hi Alexander, thanks for the heads-up!
    Will check it as soon as possible.
    As I’m still caught up in projects which involve blender 3.x LTS versions – running different versions of Verge3D on a system would still require a VM or a separate system, right?
    #86146
    Actually you can use multiple Verge3D versions if you install them to different folders with disabled “Install Blender Addon” component. After that, a specific Blender version can be configured manually as described here. The App Manager can be launched from command line from the folder of your choice (previous version of the App Manager must be stopped via “info” dialog).
    #86154
    Thomas Fabini
    That is something I really, really missed for testing purposes. I was under the impression I kept track on the forums if there was any new possibility of running more than one version of Verge3d – until I probably wasn’t.
    Thank you for your help and pointing this out!
    #86201
    Actually, we have something going on with supporting this feature. Stay tuned!
    #86265
    Thomas Fabini
    That sure sounds exciting, staying tuned!
    Installing multiple versions worked, I assume, that setting the addon up with setup.bat copies the addon to every blender version installed (and overwrites any other version). But copying manually eventually worked.
    #86412
    Glad you managed to resolve this. BTW starting from Verge3D 4.12 we’re going to support installation for the specific Blender versions.
    #86485
    Thomas Fabini
    Nice integration with the installer for choosing the specific 3d-suite versions! :good:
