SOLVED: Material color resets to previous hex value after assigning material to part
Home Forums General Questions SOLVED: Material color resets to previous hex value after assigning material to part
  • #85241
    martenmonoz
    Hello everyone,
    I’m running into a strange issue in my project. I assign a hex color value (only once) to a material. Right after that, I assign the material to a part. However, as soon as I do that, the material’s hex value automatically changes — it reverts to a color that had been previously assigned to that same material.
    I’ve attached two screenshots: one showing my puzzle logic and one showing the console log.
    Has anyone experienced something similar or knows what could be causing this behavior?
    Thanks in advance for any insights!
    I had two materials with the same name but slightly different nodes in Blender :wacko: :wacko:
    • This topic was modified 3 months, 3 weeks ago by martenmonoz. Reason: Solved
    #85247
    It’s possible that this is the cause of the issue. To assign on the material that belongs to a specific object, please retrieve that material by using the material from puzzle with the “return unique material id” option set.
    #85258
    martenmonoz
    Hi Alexander,
    Thanks for your reply! I changed the name of one of the materials now the problem is gone :)
