(SOLVED) Can’t Export GLTF and Sneak Peek with USDPreviewSurface after Update
Home Forums Graphics / Maya (SOLVED) Can’t Export GLTF and Sneak Peek with USDPreviewSurface after Update
  • #84544
    mOnz
    Hi, I just updated my old Verge3D (v4.1.1) to the latest version (v4.10).
    I’m having trouble performing the usual ‘Sneak Peek’ or ‘Export GLTF’ from my Maya project.
    I checked, and it seems like this is due to an issue with my material, which is using Maya’s default USDPreviewSurface material.
    When I tried changing to a different material, both ‘Sneak Peek’ and ‘Export GLTF’ worked.
    But I don’t want to use a different material, as it would mess up my shader and lighting setup.
    When I used the old version of Verge3D (v4.1.1), everything worked fine using the USDPreviewSurface material.
    What’s going on?
    And again, I don’t want to change the material, as using a different material makes it look terrible. :wacko:
    Thank You :bye:
    This is the error that appears when I try to export or sneak peek in Maya 2023 or 2025 :
    # V3D-PU: Performing export to preview dir: C:\Users\MONZST~1\AppData\Local\Temp\verge3d_tmp_d0u92g6w\preview
    # Error: line 1: KeyError: file C:\Program Files\Verge3D_for_Maya\maya_plugin\lib\collect.py line 56: ‘gltfCompat’
    • This topic was modified 6 months, 3 weeks ago by mOnz.
    #84546
    It appears to be a bug introduced in Verge3D 4.9. We’re going to fix it for the next Verge3D update. Meanwhile you can download Verge3D 4.8 from the download archive which should work.
    #84547
    mOnz
    Great! It worked. :good:
    Thank you, Alex!
