Camera/View Rotation Limiter
Home Forums General Questions Camera/View Rotation Limiter
  • #49060
    I have set the Vertical rotation limits in the Verge3D camera panel to 0 degree as min and 180 degree as max.
    To my surprise I can still rotate the object underneath my ground plate (located at 0/0/0).
    What am I doing wrong? How can i prevent this?
    Appreciate your help.
    #49066
    Guess I found out. The 180 degree stop in the vertical axis means from -90 to +90.
    So if I set it to 90 it does what I want. Me, not being mathematical minded thought 180 degree would lead to the lower hemisphere being neglected.
    Solved.
    #49119
    That’s right. :good:
