Verge3D 4.11 pre1 available!
Home Forums Official Announcements Verge3D 4.11 pre1 available!
Viewing 15 posts - 1 through 15 (of 19 total)
  • #84462
    We are excited to announce Verge3D 4.11 and present its first preview release for public testing. Features included:
    ☞ new e-commerce demo – Battery Shop!
    ☞ bird’s-eye camera controls
    ☞ boolean operations for morphed and skinned objects
    ☞ support for Blender 5.0
    ☞ removal of legacy code
    ☞ reworked Developer Reference
    ☞ fixed bugs!
    Check it out:
    #84463
    Outlining the Future
    Before we go into details, we’d like to outline our intentions for the future. We see our tool as a professional enterprise-grade product with a stable and fully-usable feature set, and this release represents an important shift in Verge3D development. Here is what we intend to do to achieve this long-term goal:
    • limit the number of supported versions of modeling tools to focus on product quality
    • remove features inherited from Three.js which do not fit the Verge3D paradigm and thus avoid bloat
    • prioritize improving the existing features over adding new fancy but barely useful or buggy stuff
    • ensure that all demos can be opened in all supported versions of the compatible 3D modeling tools
    • implement extensive automated testing of Verge3D releases, demos and assets packs
    • maintain up-to-date documentation highlighting most efficient production techniques
    Let us know what you think in the comments. Meanwhile, see what we have done for now.
    New E-commerce Demo: Battery Shop
    We used to have a simplistic demo with soda cans to show off how the e-commerce puzzles work, but now you can enjoy a full-scale application bundled in all three Verge3D flavors.
    As a reminder, Verge3D’s e-commerce puzzles work in the WordPress environment on top of the free WooCommerce plugin. However the principles behind this app’s procedurally generated content can be used in any applications beyond the WordPress CMS.
    This shop showcases adding an interactive 3D rendering to the simple product, the grouped product, and the variable (configurable) product as defined by WooCommerce.
    Our Battery Shop can render everything between a single item and a big pack with hundreds of items, making it suitable for retail and wholesale alike.
    On the side note, you may want to prevent reloading of the 3D scene when products are added to the cart to ensure uninterrupted customer experience. To add products on a fly, we used the free WooCommerce-enchancing plugin called AJAX Add to Cart which worked well for us.
    Blender-Specific Features
    This update breaks the compatibility for older Blender versions in the range from v.3.4 to v.4.1, so Blender 4.2 LTS is the minimally supported version now. Dropping these 5 outdated versions allowed us to remove a lot of legacy code both from the exporter and the engine – to say nothing of the streamlined asset creation pipeline.
    Also, v.4.2 and later are all based on Eevee Next which significantly changed the things when it was first introduced. So the workflow should now be more consistent across Blender versions, while simplifying the installation procedure at the same time. All applications created in the App Manager are now based on the template .blend file saved in Blender 4.2.
    But Blender continues to evolve rapidly, so we made sure that Verge3D 4.11 is compatible with Blender 5.0 which is currently at alpha stage.
    The Blender panel for exporting collections obtained icons and now filters by name correctly.
    We corrected clamping in the node Map Range – thanks for reporting this on the forums!
    Finally, we fixed the issue with Depth Write which must not be available for opaque materials, only for transparent ones.
    3ds Max-Specific Features
    When the Gradient map is added to a material, it used to create the redundant file named converted_map.png in the app folder – not anymore.
    We fixed the crash in the Backburner / CoreFinder render management systems which conflicted with the Verge3D menu. Thanks for reporting this on the forums.
    Maya-Specific Features
    The following project files and folders are now ignored by the App Manager when uploading an app to the Verge3D Network: .mayaSwatches, .mat, .mel, and .tx.
    The puzzle set camera param obtained new setting, screen space panning, which you can set to false to enable navigation like in Google Earth or in bird’s-eye view video games.
    The workings of such the type of camera controls can be seen in the impressive Gaussian splatting demo by Verge3D user nicknamed vv4d (navigate with right mouse button pressed).
    The puzzle make object from (which recently got a major update) now supports boolean operations on both morphed and skinned objects. This feature was suggested through the Enterprise support channel by two users independently of each other! Also, this puzzle now correctly works with parented objects.
    Feature Deprecation and Cleanup
    For this update we performed cleanup of deprecated JavaScript APIs which we warned about a few releases ago. List of removed classes and properties: AmbientLightProbe, MeshPhysicalMaterial, MeshLambertMaterial.specularMap, MeshBasicMaterial.specularMap, HemisphereLight, HemisphereLightHelper, HemisphereLightProbe, StereoCamera, DodecahedronGeometry, OctahedronGeometry, TetrahedronGeometry, TorusKnotGeometry, BufferGeometryUtils.computeMikkTSpaceTangents, and BufferGeometry.geometry.morphAttributes.color.
    We’re now zeroing in on a new bunch of features inherited from Three.js long ago which we consider obsolete for the Verge3D pipeline. We already removed them from the Developer Reference. If there will be no special request regarding these features from Verge3D users, they might be removed altogether in the future.
    Here the classes, methods, and properties that are deprecated with this update: AnimationObjectGroup, AnimationClip.parse(), BooleanKeyframeTrack, ColorKeyframeTrack, StringKeyframeTrack, AudioAnalyser, ArcCurve, CatmullRomCurve3, CubicBezierCurve3, LineCurve3, QuadraticBezierCurve3, InstancedBufferAttribute, InstancedBufferGeometry, CubeTextureLoader, MeshLambertMaterial, Material.alphaMap, Material.combine, Material.displacementBias, Material.displacementMap, Material.displacementScale, Material.lightMap, Material.lightMapIntensity, Material.normalMapType (drop v3d.ObjectSpaceNormalMap), Material.reflectivity, Material.refractionRatio, Cylindrical, Vector3.setFromCylindrical, InstancedMesh, LOD, CSS3DSprite, CompressedArrayTexture, Texture.mapping, CubeRefractionMapping, EquirectangularReflectionMapping, EquirectangularRefractionMapping, Texture.matrixAutoUpdate, Texture.matrix, Texture.offset, Texture.repeat, Texture.rotation, Texture.center, and Texture.updateMatrix().
    We also performed a massive cleanup of deprecated shaders inherited from older version of the modeling tools that are no longer supported.
    More Features
    Verge3D now checks mutual compatibility of the engine runtime and the glTF scene, and warns about possible issues to the browser console. If you happen to see such the message you are encouraged to do what it suggests.
    The Electron.js framework used to create desktop applications was updated to v37.2.3. We also updated the templates and documentation to make them relevant to this new version. Among new features are improved performance, security, and support for modern Web APIs. Note that Windows 7 is no longer supported, so the minimal OS version now is Window 10.
    When extracting the distribution archive under Linux or ChromeOS it no longer prints lots of warnings like “Ignoring unknown extended header keyword LIBARCHIVE.xattr.com.apple.quarantine”.
    We got rid of duplicate shader compilation when a reflection plane is present in the scene. In certain corner cases this speeds up loading time considerably.
    The puzzle product attribute now no longer returns undefined value if such the attribute does not exist for the product. Instead it return the empty string.
    Handled Bugs
    We fixed the crash in the App Manager which could happen if the v3d.js engine module was corrupted. From now on, it silently skips such apps and prints a warning in the log.
    We fixed the problem with the Verge3D WordPress plugin which failed to activate should the Editor user role be missing in one’s WordPress system for some reason. This issue was reported through the Enterprise support channel.
    Also in WordPress plugin – we fixed the problem with uploading folders containing hidden files (relevant to macOS and Linux), as well as with uploading Maya’s .tx files.
    Documentation
    We moved the Verge3D Life Cycle chapter from the Developer Reference to the User Manual and updated it too.
    We improved the chapter on using the Development Kit. Particularly we explained how you can disable Verge3D version line printed in the browser console.
    In the Maya’s Materials chapter we described how to use vertex colors.
    In the WordPress guide we added info about fixing the reloading of the product page in the e-commerce store.
    Most importantly, we invested huge efforts to overhaul the API Reference. It now focuses on features that are actually supported and – in our opinion – useful to Verge3D users. We reworked the code examples to make them work in the standard Verge3D templates, added more explanations for them, provided links to corresponding puzzles, and improved their readability thanks to an upgraded layout and a new monospaced font.
    #84464
    As usual, you can get the preview bundle from the downloads page! After installing it, be sure to update your app, to reexport glTF, and to resave your Puzzles. Let us know how it works for you!
    #84465
    Thank you for the update and the first glimpse into a road map. Here are my thoughts:
    ” • limit the number of supported versions of modeling tools to focus on product quality.”
    I personally think this is a great idea…Maya is great but not widely used….just looking at the forum tells the tale. Improved quality – fantastic.
    •”remove features inherited from Three.js which do not fit the Verge3D paradigm and thus avoid bloat”
    I have read and re-read this a few times and am wondering about what sort of things are being removed as bloat. Are these feaatures that we don’t currently have and V3D will never support or are they legacy code from ThreeJS that is just not useful?
    • “prioritize improving the existing features over adding new fancy but barely useful or buggy stuff”
    Improving existing features is always important. New fancy stuff….hmm. Well new fancy stuff that is barely useful to some may be really important to others. Would love go know whats in this category. Buggy stuff….totally understand if the bug is in ThreeJS vs V3D implementation of it.
    From an overview stand point it sounds like V3D is in a stable place and the focus is shifting to quality and reliability which is good. I am hoping we can add a few things like usability, organization, utilities that speed development but here is my continual list for improvement:
    – lighting ( bloom needs improvement but getting good lens flares, and light fog local to the light cone)
    – LOD (puzzle based control, auto LOD generation, camera radius or other controllable distance priority for LOD)
    – ability to animate using hooks (blender)
    – see Adams Verge3D tools – how about integrating those and expanding their capability?
    – still want to have the ability to turn on the javascript code in the puzzle editor and the ability to code in JS and have it show up in puzzles. This is a great way to diagnose issues with puzzles for a person not familiar with puzzles but knows JS and a great way for creatives that only know puzzles to start learning JS.
    Question – will V3D ever support DLSS or similar? Blender 5 is starting to use it but wondering if there is a chance to utilize it on the final project especially if packed as an Electron App.
    Greatly appreciate the document clean up.
    Thank you.
    #84466
    visualizer
    Hey
    V3D Team,
    I am glad that, V3D is focusing on
    Product quality
    Industry grade & production efficiency enhancement focus. :yahoo:
    After a bit of time ( I had suggested long time back in 2022 or somewhere ) but its great to see that LoD is being considered & perhaps the real professional tuning up is going to happen hereafter.
    Great!
    :rose:
    Gross level curious questions –
    1) Will Verge be focusing more on AR/VR/MR/XR based quality features?
    2) Will the glow, bloom or lens flare like features be in line with VR as well in near future?
    3) In line with the Bird’s eye view navigation feature;
    In “Gaussian splatting demo “you can notice that the mouse scroll forward moving limits and stalls after few scroll attempts can this be made a infinite scroll to move ahead.
    Once again great marching ahead. :good:
    #84467
    c4cc
    Agreed with xeon. To add, bendy bones should also be available feature in verge3d, as well as separate javascript in html’s page containing verge3d’s iframe being accessible/detected by Verge3d puzzles
    #84470
    thanks for all the feedback!
    I meant dropping older versions of each Verge3D flavors. Although Maya users are very active on the forums, sales from Maya users tell somewhat other story.
    for example 3D curves from Three.js are intended for creating simplistic procedural stuff with pure JavaScript and are not exported from the 3D tool where curves are based on NURBS – so we remove the former and use the latter.
    does not mean that we stop adding features – just become more cautious when picking some feature for implementation.
    #84471
    regarding the features you guys suggested, we’ll think about them! :good:
    #84479
    Just looking at the Maya forum listing and the last real user seems to have put in an entry over 9 months ago and if sales are not what they should be…save the effort and put it towards Max and Blender. I know there will be some upset MAYA users but in the end Max and Blender versions will be that much better.
    #84487
    visualizer
    HI
    Yuri & team
    Any views on the point number 1, 2 & 3 ?
    • This reply was modified 6 months ago by visualizer.
    #84499
    c4cc
    Also, how nice if puzzles could be activated before app is loaded (optional feature via tickbox)
    #84501
    we’ll think about it!
    #84524
    Pandern
    Why the hate for us Maya users? :heart:
    I think you misunderstood Alexanders reply. I think he forgot a ‘not’, and the line should read that Maya users aren’t that active on the forum, but the sales doesn’t reflect the forum activity. So there are more of us than the forum activity implies.
    B-)
    #84525
    Yep, it was a typo! Maya strong :yes:
    #84535
    Not hating on Maya users, I am one as well. From a business perspective Soft8soft could ….lighten their development load, concentrate on just two platforms, raise the price and be more efficient and cost effective ……. The percentage of Maya users that use V3D is small compared to the other platforms.
    Of those Maya 3D users, how many use it primarily for V3D commercial work vs participant users using a student or trial license? Business that use V3D commercially quickly realize the cost benefit of Blender vs other options and dump paid 3D modeling apps by hiring or training their teams to use Blender. The cost savings is so large business start swapping as soon as they commit to V3D.
    My point is not hating on Maya users or Maya as an app. My point is V3D is loosing active users as can be seen by forum activity, keyword search analysis, etc. It needs to grow and the best growth will be with its biggest base of users. There are other webgl platforms that are competing and V3D needs to grow to stay in the fight. I want V3D to thrive and for Soft8soft team to concentrate on what matters…. The tools… not the platforms.
