V3D for Blender: Map range clamp doesn’t work
Home Forums Bug Reports and Feature Requests V3D for Blender: Map range clamp doesn’t work
  • #83411
    vklein
    V3D 4.10 for Blender:
    Activating the “Clamp” checkbox on the “Map Range” node in a Blender shader did not carry over to the V3D shader. The output is still unclamped to the output range. Using a separate “clamp” node after the “map range” node works as a workaround for me right now.
    Please implement it, WYSIWYG is always better.
    #83423
    Consider it’s done since we’re going to support the clamp setting properly in the upcoming Verge3D update.
