Unable to rename/edit names in puzzles
Home Forums Puzzles Unable to rename/edit names in puzzles
  • #35030
    j.nelligan
    I am unable to edit/rename puzzles when I drag them into the workspace. I am using 2.17.1. It was working up until a day ago.
    Any help would be greatly appreciated.
    Thanks
    Brendan
    #35039
    Hi Brendan,
    if you create a new project, do the Puzzles work for you? Are there any errors in the browser console (F12 then switch to console tab)?
    #35044
    j.nelligan
    Hi Yuri,
    Thanks for the quick reply. I created a new project and the renaming works again. The inspector wasn’t showing anything strange but I just copied the files to the new app and it was quiet early in development so I will redo what I have done.
    Thanks again
    Brendan
    #35055
    If case it helps, the Puzzles editor makes backups (located in your_app/v3d_app_data/puzzles_backup) each time you save your puzzles.
