Problem with set display to none/ Webflow object
Home › Forums › Puzzles › Problem with set display to none/ Webflow object
  • #40379
    hannahmariasch
    Hi!
    I want to hide an image or div, created by webflow in verge3d with: set style display to none in parent doc – on event of click.
    It doesnt seem to work.
    What could be a possible mistake?
    Thank you! :bye:
    #40405
    Is the click event puzzle even triggered on click? You can test that by adding a “print to console” puzzle inside and see if it prints anything.
    Also, make sure that you specified the correct element id in the “set style” puzzle. It should look something like this:
    Also, there could be errors in the browser console if something goes wrong, it’s worth checking out.
    #40407
    hannahmariasch
    Yes, Thank you – Its all working now!
