Issue with verge 4.10.0 and blender 4.5.2
Home Forums Bug Reports and Feature Requests Issue with verge 4.10.0 and blender 4.5.2
  • #84854
    luma
    I was using Verge3D 4.9.2 for a long time with blender 3.4 and 4.3.2, no problems with that but today my coworker has this issue with a 3D model that I modeled and tested in my computer. so he had Verge 4.10.0 and blender 4.5.2, he could solve this problem so I upgrade my version of verge3D and blender, and I had the same problem exporting. He try blender 4.3.2 and it worked.
    short story, Verge4.10.0 works better with blender 4.3.2 than blender 4.5.2
    https://i.ibb.co/ks77LKxR/versions-issue.png
    Note: Is not a problem with normals or materials set as front/back or both sides or puzzles
    • This topic was modified 6 months, 1 week ago by luma.
    #84865
    When migrating from older Blender versions, sometime Blender adds Transparent BSDF and Disable Shadow nodes to the material:
    Transparent BSDF and Disable Shadow nodes in Blender
    Since Verge3D uses the “Auto” transparency mode by default in Blender 4.2 or later, it treats such a material as transparent which might be not what you want. Please remove these unnecessary nodes from your materials or just set the transparency mode to “Opaque” explicitly.
    #84883
    luma
    I have reviewed the affected materials and none of them have more nodes than necessary, also the transparency mode is set to “Opaque” and it still has this problem.
    #84885
    Could you please assign this material on a simple model (like a cube) and send such minimal reproducible example to us for further investigation?
