Fit to camera not working?
Home Forums Graphics / Blender Fit to camera not working?
Viewing 15 posts - 1 through 15 (of 20 total)
  • #82586
    c4cc
    It is actually possible without coding. You can use an empty object parented to the camera, with your object parented to this empty. Both empty and your object should have camera fit enabled, for example: to the left and to the bottom. See attached file.
    I tried, but unfortunately, it did not work?
    https://postimg.cc/4mBbkxTY
    https://postimg.cc/nXrKHfH0
    https://postimg.cc/75R3hthD
    As per this quoted post, fit to camera is not working
    • This topic was modified 9 months, 1 week ago by c4cc.
    #82591
    Did you clear the parent inverse for the empty?
    #82595
    c4cc
    I did, sadly nothing
    Edit: to do camera fit:
    1) create a dummy object to parent to camera
    2) parent dummy to camera
    3) clear parent inverse
    4) copy name of original intended object
    5) join original intended object to dummy object
    6) rename joined object with name of original
    7) shift+S to assign cursor to selected over targeted vertices to appear in camera viewport
    8) deleted unwanted vertices misaligned due to fit to camera:
    9) Choose “fit to camera” settings
    (left in this case)
    Optional
    Parent other object to “fit to camera” object
    1) Keep transform in this case to prevent vertex colors becoming black
    2) Sensor fit for camera
    • This reply was modified 9 months ago by c4cc.
    #82596
    What version of blender and V3D are you using ?
    #82597
    c4cc
    Blender 4.2, V3d 4.9
    #82600
    Here is a sample cube..parented to an empty that is camera fitted to upper right corner.
    Its using Blender 4.2.3 and V3D 4.9.2. Its working….take a look and see if it works for you.
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:f2f27a4091/X3L_cam_fit_4_9_2_test.zip
    Blender file included.
    #82602
    c4cc
    Unfortunately it only works for verge3d viewport
    https://postimg.cc/zbm8dFVN
    https://postimg.cc/xXTCH5bF
    On the other hand, not so in sneakpeak:
    https://postimg.cc/qtJ8N2kk
    https://postimg.cc/0MBkY1Dt
    Hi, It is actually possible without coding. You can use an empty object parented to the camera, with your object parented to this empty. Both empty and your object should have camera fit enabled, for example: to the left and to the bottom. See attached file.
    Only from here does Yuri’s fit to camera actually work
    • This reply was modified 9 months, 1 week ago by c4cc.
    #82606
    You might open the browser console to see if there are any issues printed there. Fit to camera feature should work exactly the same for exported gltf and Sneak Peek.
    #82608
    Working in sneak peak and exported fie me.
    #82610
    c4cc
    Sneak peak:
    Nothing mentioned
    First, I tried to parent to camera:
    Then I used fit to camera:
    https://postimg.cc/CBYj91MQ
    Unfortunately no changes, not even with auto, horizontal, vertical camera fit
    #82614
    Is it the same version printed in the sneak peek mode and the regular app?
    #82617
    c4cc
    It only works in viewport for verge3d library, but sneak peak, no
    #82619
    Could you please share exactly the same blend file that fails? The version you provided in your initial post definitely has parent inverse issue.
    #82621
    c4cc
    The original blend file
    #82623
    The console clearly states that the parent inverse matrix should be cleared for both t1 and t2:
    BTH, considering the high prevalence of this problem we decided to implement checks and a warning message right on the “Fit to Camera Edge” panel in Blender. New feature will be available in the upcoming Verge3D update.
