First person camera strafe movement
Home Forums Puzzles First person camera strafe movement
  • #30753
    core3d
    I’m still trying to build a physics enabled FPS movement with puzzles. Forward and backward movement is working but i can’t figure it out how to calculate left-right vector calculations.
    i found how to calculate left vector on web but i’m not sure how to apply this with puzzles.
    var vectorUp = new THREE.Vector3(0, 1, 0);
    // Left vector
    var coefficient = Player.SPEED * delta * this.q;
    this.v.copy(new THREE.Vector3().crossVectors(vectorUp, cameraLookVector).normalize().multiplyScalar(coefficient));
    // Right vector
    this.v.copy(new THREE.Vector3(1, 0, 0).applyQuaternion(camera.quaternion).multiplyScalar(coefficient));
    Three.JS FPS Controls Strafing Left and Right
    Help…
    #30832
    This is quite easy to do with Puzzles. First, get horizontal object direction vector with the get object direction puzzle, then apply 90/-90 degrees rotation with vector math and then add to current object position using the same puzzle.
    #30847
    core3d
    Yes it’s works thank you.
    #30855
    :good:
