Change material only when object has been clicked on using buttons.
Home Forums Puzzles Change material only when object has been clicked on using buttons.
  • #35330
    maxmaker118
    Hello,
    I am trying to make an object change material when clicking on a button but only when it is clicked on in the 3d viewer before it is able to change color by clicking on the button. ( I hope that was clear :scratch: )
    The only part I don’t know how to do is clicking on the object in the 3d viewer before allowing it to be changed by clicking on a button. And making this happen for multiple objects but using the same buttons to change them.
    #35366
    you can use a variable to track if the 3D object was clicked, and then check this variable to only allow button action if the 3d object was clicked.
    https://www.soft8soft.com/docs/manual/en/puzzles/Variables.html
