App missing puzzle elements.
Home Forums Puzzles App missing puzzle elements.
  • #84841
    wayneadams
    My Verge3d app contains a GTLF exported from 3ds max and a Gaussian Splat from SuperSplat and a menu of three buttons.
    My issue is when I run the App.. the only thing that shows up is the splat. No GTLF, No buttons from the puzzle editor.
    When I run the HTML The buttons and GTLF show up but not the splat.
    These are screenshots of what I’m doing:
    https://imgur.com/a/verge-3d-issue-8c80IvO
    Some additional info:
    The plug in I’m using:
    https://vv4d.gumroad.com/l/LumaSplatViewer
    Apologies if this has been asked and answered but I’ve been searching around and haven’t seen anything quite like what I’m experiencing. Thanks in advance!
    Wayne
    • This topic was modified 6 months ago by wayneadams.
    #84843
    Hi Wayne,
    It is probably an issue with the third-party plugin. You might want to create a reply in the plugin topic so that the author can help you out.
    #84850
    QiangGe
    Hi Wayne,
    this is indeed what happens when Luma’s plugin loads both Gaussian and scene models simultaneously. It’s an unresolved issue related to envmap. Since Luma only provides a Three.js API and isn’t open-source, it can only load their online models. Therefore, we later switched to using the 3DGSviewer plugin as a replacement. If you encounter any problems, feel free to contact me via email.
    #84851
    wayneadams
    Hi QiangGe,
    I am currently using the 3DGSviewer, not Luma.. and still getting that behavior. Will follow up in an email. Thanks!
    #84852
    QiangGe
    Hi QiangGe,
    Hi, there are 2 inspection methods. In most cases, the editor needs to check the information reported in the console, such as whether there are any errors.
    In addition, if the loading is successful, we can find the name of the loaded Gaussian under the object’s puzzle. Without this information, I cannot determine the cause of the issue.
    Based on the current situation, my guess is that the scale of the loaded model may be extremely small or it may be too far away, resulting in it not being within the camera view.
    You can share your demo file with me for download and inspection.
