The html menu does not work or partially works on the local host
Home Forums Bug Reports and Feature Requests The html menu does not work or partially works on the local host
  • #48025
    zhenia
    Hello, I have a problem, there are several projects in, made according to the same template, in all of them there is a html menu made that interacts with the model. So if you run the model from the app manager, everything works fine. But if you embed a model into a website on WordPress, then some models work as expected, and for some, a partially or completely written additional menu does not interact with the model. Once again, the loaded models from the app manager work fine exactly as I intended. The site is on my local hosting, maybe this is some kind of problem? I make a link to the model through html insert into the page, the model is displayed but the menu works only in some projects, the most surprising thing is that there are projects in which the menu works partially, although there is nothing unique there. I tried it through a special plugin for Verge d, after updating it to the current version, it stopped displaying the model on the page altogether. Any idea what I might be doing wrong? Thank you
    #82108
    There is a possibility this is a cross-origin resource sharing (CORS) issue. This should be fixed in Verge3D 4.10.
    X | FB | LinkedIn
