Rendering on Scanline but Blank on Verge3d
Home › Forums › Graphics / 3ds Max › Rendering on Scanline but Blank on Verge3d
  • #53687
    jhoniolinger
    Guys, I’m a layman in 3ds max and also in verge3d. I bought it to perform a simple service. However, I got stuck on something here that I can’t find myself to know what I’m doing wrong.
    in ART Arnold or Scanline, it’s rendering normally, but if I do a Sneak Peek, the object comes out blank, as if it has no texture. Can someone help me??
    #53692
    Hey there…hopefully you run into a Max person that can help in more detail but the answer is more than likely your material setup is not compatible with Verge.
    Other possibilities include:
    too much light
    emissive material
    very strong environment map
    I would recommend testing the following:
    1. assign a basic color texture to your object and retest.
    If the basic color (red) is assigned to all your objects and it still comes out white…then you know you should look at lighting
    If the object comes out the color you chose then check your materials and make sure the specularity, roughness etc are set so they don’t wash out.
    Good luck
    #53693
    You state you are a “layman” in max….you could save yourself some money out of your pocket if you use Blender and achieve the same results for $0 per month. But more importantly, the Blender/Verge3d community is much more active and you will get more help right away. My humble two cents.
    #53697
    Seems like the nodes next to bitmap nodes are not supported. Better not to use scanline, we have a plan to remove it’s support completely in near future.
    #53716
    jhoniolinger
    I found this notification inside maxscript
    V3D-WARNING: Unsupported material type: Autodesk_Material
    Would it be the aUtodesk materials that are not supported??
    #53743
    Yes, seems like that’s the reason.
