Problem Using Math Nodes
Home Forums Graphics / Blender Problem Using Math Nodes
  • #84672
    JT
    Hello everyone, :-)
    I have created a radar style animation in Blender using various nodes, including math node, and all works fine within the blender viewport. But when I export the .gltf file, the animation does not work. I just wondered if I am doing something wrong, or, maybe my node setup is not fully compatible with the current version of Verge 3d? If that is the case, maybe someone could suggest an alternative method for achieving a similar result in Verge 3d? ;-)
    I have attached my blend file below, and any help with this would be greatly appreciated.
    Many thanks in advance.
    I checked out your file. The driver which is used to animate the “Value” node is not supported in Verge3D. You might just replace it with a regular keyframe animation to make the demo work (BTW cool effect!).
    #84720
    JT
    Hi Alexander,
    Sorry for the late response (I’ve been travelling for the last couple of days). Thanks for the advice regarding key frames, I’ll look into keyframing the animation as you suggested. As as side note: The idea behind this was to create an circular animated main menu. When I get a solution, I’ll post the blend file.
    Thanks again. :good:
