How to use puzzles and ES6 together
Home Forums Programming How to use puzzles and ES6 together
  • #85128
    omeletee
    Hello
    I want to try out these examples and keep the puzzles, but they all use ES6 syntax.
     <script src="v3d.js"></script>
      <script src="addons/EffectComposer.js"></script>
      <script src="addons/OutlinePass.js"></script>
      <script src="addons/RenderPass.js"></script>
      <script src="my_awesome_app.js"></script>
    This won’t work because they both use “import”.
    How can I make them compatible?
    Thank you for your attention
    • This topic was modified 4 months, 2 weeks ago by omeletee.
    #85133
    Unfortunately the Three.js examples are outdated and no longer supported in Verge3D. You should take newer ones directly from the upstream and port manually.
    The good thing, is that many nice features are already ported to v3d.js runtime or Puzzles. For example, all 3 addon modules used in your snippet has been integrated in the Verge3D core long ago.
    #85134
    omeletee
    Thank you for your work.
    I noticed the functionality in Puzzle, but it doesn’t allow for adjusting the outline, whereas the Three.js component does.
    Is there a way to use ES6 syntax?
    I tried using v3d.module.js from npm
    , and it seems to work. Is this the correct approach?
    Thanks again for your reply
    • This reply was modified 4 months, 2 weeks ago by omeletee.
    #85138
    Sure you can replace v3d.js by v3d.module.js in your application! However, this setup should be maintained manually (e.g. you should not update your app with the automatic update feature).
    #85160
    omeletee
    Thank you for your reply, it’s very helpful.
