How to change the world material?
Home Forums General Questions How to change the world material?
  • #20391
    karl36
    Excuse,I have a question. How to change the world material on the puzzles ? I can see the world material on the puzzles. I want to replace the material by selecting the object. But the world does not belong to the object. How can I do it on the puzzles?
    #20392
    You cannot replace the world material, however, you can modify it using set value and set rgb puzzles. See the Scooter demo where the light environment is replaced by the dark one.
    #65372
    konstantinos
    the “set value in material” puzzle only shows object materials in the list. It doesn’t show world material, so how can I modify value from puzzles?
    #65373
    A simplified approach would be to have two world images in your application directory.
    When you export a scene your world texture is put at the root of your application. You could copy another environmental HDR there or whatever you want to use.
    Then use a “when clicked “puzzle and inside it use a “replace texture” puzzle. You then have access to the Verge3D_Environment_World and you can assign your new texture to it. You of course could trigger this change in any manner you want.
