Home Forums Graphics / Blender Fit to camera not working?
Viewing 5 posts - 16 through 20 (of 20 total)
  • #82629
    c4cc
    Thanks. Is parent inverse matrix a default setting for objects, or does it arise due to other factors like puzzles?
    #82636
    This parent inverse matrix is created by Blender when it tries to preserve the position of the parented object. It causes additional offset which is not compatible with the camera fit feature. That’s why the error is printed in the browser console.
    #82641
    c4cc
    I tried to use clear parent inverse:
    yet object got parented to camera:
    Is this normal? Or does the “Set parent to” type prevent this? If so which one?
    #82642
    Unfortunately yes. This is because that parenting occurred when the object had zero transform. So once you clear its parent inverse matrix, it got the same zero transform, but this time relative to the camera. After you clear parent inverse you should reposition the parented object back to what you need.
    #82643
    c4cc
    Thanks. So when I parent object to camera using “set parent to”, which one do I use?
