- This topic has 21 replies, 3 voices, and was last updated 2 weeks, 2 days ago by
c4cc.
2024-12-28 at 8:12 am #79571
albi
ParticipantI am trying to create a first-person walking experience where a character’s walk animation is triggered by pressing a specific key on the keyboard. The camera should follow the character from behind, similar to how it works in many video games. However, I do not want to parent the character to the camera, as I want the user to have the ability to rotate the camera around the character, allowing them to view the front of the character and the surroundings (like in GTA games). Additionally, the character should always stay on the floor.
### Key Queries:
1. How can I assign specific keyboard keys to trigger actions using puzzles in Verge3D?
2. How to do the first person character walk properly like in video games using Verge3D?Thanks in advance.
2024-12-28 at 4:17 pm #79577c4cc
CustomerPardon if this isn’t exactly spot on, but full credit to kdv for teaching me the basics of keydown here
and if necessary, logic puzzles
If necessary?
Without logic puzzles you will do nothing.
2024-12-28 at 4:38 pm #79579c4cc
CustomerWhile kdv must absolutely be credited for teaching me the fundamentals of keydown/up events, here’s the puzzles for keydown/up events for movement I ended up with eventually. Just change “up” to “forward”, and “down” to “back”
Also, assuming you’re using Blender…
speaking of 3d camera view, a la GTA games, the camera has to be moved around together with the playable character via the above controls, too. Here, the puzzles do so:
Meanwhile, in Blender, the camera verge3d setting must be this, so camera may be controlled via mouse:
2024-12-28 at 8:49 pm #79581kdv
ParticipantI want the user to have the ability to rotate the camera around the character, allowing them to view the front of the character and the surroundings (like in GTA games). Additionally, the character should always stay on the floor.
that’s quite possible. and even without JS coding ))) but the First Person camera controls won’t do. you’ll have to create your own controls. somethig like shown above…
2024-12-29 at 7:35 am #79582albi
Participanthere’s the puzzles for keydown/up events for movement I ended up with eventually. Just change “up” to “forward”, and “down” to “back”
A huge thanks for your time and effort you have put to this. Since I’m not familiar with most of the puzzles you have shown, I’m going through user manual and studying all those puzzles one by one and trying it out. I just want to understand how this works and what’s happening rather than just copying those puzzles as it is.
@kdv That’s pretty much from the attached YT video I want to achieve.
Also how can we trigger multiple animations of the character to assign in various events. In the video you have shared, I’m seeing an idle animation and walking animation in the same character in different scenarios.
I have tried this but Verge3D seems to recognize only animations to a mesh, not importing multiple strips or actions from Blender.Also, can u share the puzzles tree of the application in YT video if you have it. Sorry if I’m asking for too much.
Thanks so much.2024-12-29 at 9:16 am #79583c4cc
Customerthat’s quite possible. and even without JS coding ))) but the First Person camera controls won’t do. you’ll have to create your own controls. somethig like shown above…
From my experience, leaving camera Verge3d setting as “orbit” allows the camera angle to be manipulated via mouse, a la FPS shooter, doesn’t it?
2024-12-29 at 2:58 pm #79586kdv
ParticipantI’m seeing an idle animation and walking animation in the same character in different scenarios.
https://www.soft8soft.com/topic/verge3d-tools-plugin/page/2/#post-67807
Example https://v3d.net/16lgPuzzles and JS coding. Fast and expensive.
2024-12-31 at 8:44 am #79599albi
ParticipantHi kdv, Thanks for the response.
I this achieved by using any plugins? cz I’m not seeing some of the puzzles from the image you hve shared.2024-12-31 at 8:50 am #79600albi
Participantthe camera has to be moved around together with the playable character via the above controls
As far I understood, you are only moving the camera left and right, Isn’t it?
I’m trying to create a character that moves left, right, forward nd backward. So, is it the same method I need to repeat to give forward nd backward cam movement with the character?2024-12-31 at 8:51 am #79602kdv
ParticipantOnly one puzzle is not standard and it’s not important in your case. This puzzle is just used for smooth cross-fading…
2024-12-31 at 8:57 am #79603albi
I not able to find “set effective weight for animation” puzzle also. what about that?
2024-12-31 at 8:59 am #79604kdv
all the rest puzzles are standard ones.
2024-12-31 at 9:45 am #79606c4cc
CustomerAs far I understood, you are only moving the camera left and right, Isn’t it?
I’m trying to create a character that moves left, right, forward nd backward. So, is it the same method I need to repeat to give forward nd backward cam movement with the character?Yeah, my camera’s moving left and right.
In your case, you want the camera to be controlled gta style.
So your camera must be moved forward and backwards via player controls as well, with “orbit” setting chosen under camera verge3d options in Blender. Apply the puzzles for moving camera left and right to keydown/up events for moving forward and backward, but change the number to Z axis instead of Y axis.
2025-01-07 at 2:26 pm #79695albi
Participantto be controlled gta style.
Example
I want to trigger multiple animations, ie Walk animation when walking and Idle animation for the rest of time.
Unlike the example shared by kdv, I’m trying to trigger the animations when the Keys are pressed, not in the event of clicking any mesh.I have tried as below (PFA) but it’s not triggering the specified animation.
What’s the right way to do this?
2025-01-08 at 6:27 pm #79712c4cc
CustomerRemove “every frame” for your animations
