Editing visual_logic.js
Home Forums General Questions Editing visual_logic.js
  • #32984
    shruthy
    I made some code changes in generated visual_logic.js. But when i refresh the puzzle editor and save, the code in the visual_logic.js gets restored to old one. Is there a way to retain visual_logic.js even if i make a change in puzzle editor.
    Thanks,
    Shruthy. B
    #32988
    you can try to separate the code that you write manually from the code that is generated by the Puzzles editor.
    https://www.soft8soft.com/docs/manual/en/introduction/Using-JavaScript.html
    Alternatively you can acquire the Enterprise license and edit the code that is generated by puzzles (or add your own puzzles).
