CORS problem when i need to load scene from another domain
Home › Forums › General Questions › CORS problem when i need to load scene from another domain
  • #45357
    core3d
    I’m trying to use a loadScene puzzle for calling a gltf model from a database on another domain. But I’m getting a CORS error when I call gltf model. Those two domains are configured to work together already and there is no problem with that.
    Can I add custom headers to loadScenes fetch requests?
    I’m using VueJs by the way.
    My code is:
    sceneURL = initOptions.useCompAssets ? sceneURL + '.xz' : sceneURL; // sceneURL comes from REST api (file contains on another domain (REST API's domain))
                window.vergeApp.loadScene(sceneURL, function() {
                    window.vergeApp.enableControls();
                    window.vergeApp.run();
                    if (v3d.PE) v3d.PE.updateAppInstance(window.vergeApp);
                    if (v3d.PL) v3d.PL.init(window.vergeApp, initOptions);
                    vue.runCode(window.vergeApp);
    #45358
    core3d
    Ah, sorry i didn’t see that :
    https://www.soft8soft.com/docs/api/en/loaders/GLTFLoader.html#setCrossOrigin
    I will try this one, i hope i can solve with it.
    #45456
    core3d
    Nope, unfortunately not working. CORS is properly configured on server side, everything else is working. Even though i set setCrossOrigin and credentials. Looks like XMLHttpRequest headers can not return with loader and getting “No ‘Access-Control-Allow-Origin’ header is present on the requested resource.” error.
    #46347
    core3d
    i figure it out. This thread can be removed.
    #46350
    If you would please edit your thread title and add [SOLVED] at the beginning. It will help identify if a post is still active until there is a better way. Otherwise, everyone just has to go through the thread :-)
