Accessing Object Within glb or gLTF
Home Forums Programming Accessing Object Within glb or gLTF
  • #13583
    anomalyproductions1
    Hi there,
    I’ve been having great luck appending glb scenes to my project that is already running on the web, but how to I access the individual models of the glb file, once it’s been loaded? Do I parse the data outside of the puzzle editor?
    Best. :)
    #13584
    anomalyproductions1
    Just to add some more context, I’d like to maybe see the name of a model appear on a div element once it’s been loaded, or get a notification of some kind.
    #13594
    Object names in the exported files are basically the same as in the source .blend or .max file.
    #13602
    anomalyproductions1
    Thanks for getting back to me! I guess my question is, how can I access glb or gLTF nodes within Verge3D so that I can dynamically fetch names after the file has been uploaded.
    #13603
    This can be done with some programming. First, you need to obtain the loaded scene:
    var scene = app.scene.getObjectByName("path/to/your/scene");
    Then, you can search for objects in your scene as usual:
    var objNameList = [];
    scene.traverse(function(obj) {
        objNameList.push(obj.name)
    #13605
    anomalyproductions1
    traversing the app scene is working! last question, and it’s a silly one. How can I get a URL from the newly loaded file? I only ever see base64.
    Thanks again for your time, it’s greatly appreciated :)
    #13606
    it is accessible via scene.name
