The “Change” event Handler is not working ..!
Home Forums Puzzles The “Change” event Handler is not working ..!
  • #29109
    aminemod
    Trying to listen on a dynamicaly filled input type : “text”, as mentioned on the documentation. the event doesn’t fire when the value of the input changed !
    would you please if there is any error !
    here how the event looks like on my Puzzle : (find the screenSHOT attached)
    THANK YOU :D
    #29362
    kubuz
    Hi everyone,
    I have the same problem.
    @Animemod Did you find the solution to this ?
    #29375
    From the posted screenshot it looks like the puzzles are correct.
    Here’s an example project: test.zip. If you open it and input 1.jpg in the text field and press Enter the texture will be replaced with a different one.
