Simple drag position and reset memory query
Home › Forums › Puzzles › Simple drag position and reset memory query
  • #87191
    visualizer
    Hi
    Is there a way where I can assign the reset original position to the dragged object or grabbed object?
    example –
    The object in scene is draggable and can be positioned anywhere.
    After few seconds or upon certain interaction can that object be made to go to its original orientation?
    if yes can that resetting of position & rotation be with some smooth transition instead of hard jump?
    #87206
    It’s quite possible. Just save the original object coordinates (XYZ) into some variable and restore them when necessary. For smoother transition, you should use the animate param puzzle to interpolate current position to that original coordinates.
