Scene (Switch) or (Hide) Object?
Home › Forums › General Questions › Scene (Switch) or (Hide) Object?
  • #49980
    peterpennl
    Hi Everybody, here a rookie regarding Verge and coding.
    I’m testing a project with the following details;
    A body has around 60 poses, you can see the outer layer (Skin) and the inner layer (Bones). This material swith to transparent is already in place.
    But now I hit a brick wall. Do I switch to another scene (a new pose) or do I hide this object (pose) for a new one?
    Scene switching sounds more logic then hide and show 60 poses/object and making the interaction complex.
    I can’t find any examples of how these 2 puzzel work and which one is best fitting. :scratch:
    Hope you can help me out!
    Thanks ins advance, greets form the Netherlands :bye:
    #50005
    hi,
    a possible solution might be creating 60 frames of animation and using the set animation frame puzzle to switch between poses
    #50007
    peterpennl
    First of all, thanks for replying!
    I’ve thought about this solution also.
    But switching between different poses can trigger some awkward movements/motion on legs and arms etc.
    In other words; 60 poses X 59 other poses results in at least 357481 combinations of arms and legs going all over the place before landing in right position.
    But let say you click on a pose and there is a white fade in and out to mask these awkward (not controllable switches) and then you see the new pose, I’ll be happy with it!
